Supercharger not charging to set limit
Michelle_eriw
545
317
I have the M3 LR set to charge to 85%. While charging at a Supercharger today, I got an alert that the car was charged to 80%, and the 5-minute grace period was starting.
Could this shortfall be because all eight Superchargers were in use?
If it matters, the nav system had no destination set, so the car and Supercharger didn't know how far I would be driving.
ucmndd
6,688
12,560
Yes. There will be an alert message on the screen when you plug in informing you that you’re at a “high usage supercharger station” and your charge limit has been set to 80%.
You can override that by changing the limit back to whatever you want it to be after you plug in.
s33t33
51
24
Wi
The charge rate drops off after 80% anyway (to protect your battery), so unless you really need your car to hit 100% so you can reach your next SC destination, then the charge rate vs time you will be stuck at the SC isn't beneficial to you or others waiting behind you (if the SC is busy)
Reactions: toolman335
Michelle_eriw
545
317
It wasn't a matter of 80% vs 100%, but rather 80% vs 85%.
Michelle_eriw
545
317
Gasaraki
1,844
1,146
Syracuse, NY
Yes... It tells you. Charge is limited to 80% due to high usage... bla bla bla. If you needed to travel someplace far where you need more charge, it says you can go change it....
