Hi All,
Trying to figure out the clearances to avoid rubbing. Have the performance and wanted to add a little more cushion (wider, taller tire). I cant find the clearance data on the suspension components. Would love to hear if anybody thinks the following setup will rub.
Uberturbines:
Front stock 255/35/21 to proposed 265/40/21
Rear stock 275/35/21 to proposed 285/40/21
The tires (both front and rear) are about 1.4" taller and 0.5" wider. So, for clearances, would need 0.7" clearance for taller and 0.25" wider.... Anybody have the measurements to see if this setup will work? Speedo would be off by 4%. Dont care about the speedometer but wanted to see if I can get away with cushier tires.
-Would this in any way affect alignment?
-Any other considerations to note here?
Thanks for the feedback.
Uberturbines:
