Swapped wheels = less regen + lighter steering wheel
I just swapped my 20" Slipstream factory wheels to the Tsportline 20" wheels.
Post-swap, I am noticing two things:
1. Steering wheel feels lighter than before (Sports mode)
2. Regen braking is now less stronger (Normal regen)
Trying to figure out what caused the above. Wrong torque on wheel lugs? Something else the tire shop overlooked? Difference in weight on the wheels?
New wheel weights
Front - 20×9.0″ = 32.8lbs.
Rear - 20×10.0″ = 34.8lbs.
Should not be much different than factory ones?
Here are the OEM wheel specs ... you are right between the 19" and 21" wheel weights :cool:
The Tesla Model S Wheel Guide - Tsportline
19″ Slipstream Wheel
  • Size: 19X8.0″
  • Weight: 29 lbs
21″ Turbine Wheel
  • Front 21×8.5″ = 35.2 lbs
  • Rear 21×9.0″ = 38 lbs
