Hope you guys can help...
Firstly, I installed those Amazon bumper lights that replace the lower reflectors with cool lamps about a month ago, but since install, everything has been fine.
Suddenly this weekend, the passenger-side brake light stopped working - running/parking still working.
So, I took the aftermarket harness out and re-connected the stock plug directly into the tail light - no change.
I then pulled the connector out and blew air in it, then plugged it back in - all lights not working now. Running, brake etc. This is also on the trunk lights too.
I then removed the aftermarket harness from the drivers-side and now ONLY the brake works.
Not sure whats going on but the plugs look good and they are pushed in all the way. What is going on here?
THANKS!
THANKS!
