Very unlikely. Lithium batteries don’t like to be discharged to zero.When the iPhone 6 came out, wasn't Apple's recommendation (at that time) to discharge the battery down to zero at least once per month?
Very unlikely.
Regardless, maybe my phone analogy was a bad one. I just assumed everyone plugs in their phone every night without thinking about it or checking the charge level, so they could relate to plugging in the car every night the same way.
So we have 2 orders in for model 3s. We recently bought a house that said it was prewired for everything charger. This is what they meant in the garage. Will this work for a Tesla charger? How fast will it charge? Can we plug a Tesla wall charger into this or do they have to be hardwired? It has on it:
Nema 14-50R 50A 125/250V.
The manual suggests that it is better to keep it plugged in at all times.Fair enough but what about folks who don't drive everyday, or perhaps only every third day? Is it "better" for the battery life to remain plugged in all the time, and just remain at ~80% charge constantly?
That’s not what you are supposed to do. Have you read the manual? The part about the battery that is IN UPPER CASE AND BOLD PRINT LIKE THIS?
Plug the car in every night. Don’t wait until you think it “needs it”. Let the battery management system manage the battery.
You don’t decide whether or not to plug your phone in at night based on how much charge it has left or how much you plan to use it the next day, do you? You just plug it in. Do the same for the Tesla.
Sounds good. I’ll continue to do what Tesla recommends (as I started doing 5 years ago with my Model S) and you do what you think is best. But for those owners who have not read the manual, and aren’t aware of Tesla’s recommendation to “LEAVE YOUR VEHICLE PLUGGED IN when you are not using it” (their upper case, not mine) perhaps my post and those by others such as @chronopc will be helpful.Dude, relax. Sheesh.
There is a ton of data that suggest batteries last longer when maintained between 50-80%. Letting it discharge down every once in a while is supposed to be good for batteries. I read manuals and read the one for the Model 3 three times. But I do not blindly follow all directions. I research and do what I think is best. Many days we put 20 miles on the car. I'm not going to ping pong between 75-80% all the time.
Suggestion: you do you and let me do me.
Honestly I'm not sure I would trust a builder installed 14-50 outlet. https://www.tesla.com/sites/default/files/downloads/US/universalmobileconnector_nema_14-50.pdf explicitly mentions 2 brands of high quality, industrial grade receptacle.
Also since you will have 2 cars needing charging the 2x HPWC route seems to be the way to go.
You would need to open your circuit breaker box and see what amperage breaker it has. Each breaker is labeled on the switch with the amperage and hopefully there will be a decent label inside the box that shows you which breaker is connected to the outlet in the garage. You never want to rely on the label being correct without testing it yourself - easiest way is to measure the outlet with a multimeter or tester, then turn off the breaker you think is the correct one and measure again. Once you've verified which breaker is connected to the outlet, you'll know exactly how much power it will provide and how fast you can charge.What do you mean did the builder confirm that? They didn't confirm anything, just stated the house is prewired for EV charging and that is what is written on the plug. How would I verify without paying for an electrician?
Why do you not trust the builder? It seems stupid for a developer to promote offering a NEMA 14-50 outlet and not build to code (chances are the inspector may not notice when during final inspection but it is a huge risk to take for such a small item). At that point, you should be more concerned about the entire electrical system or plumbing system for the house.
