I have a 2017 Tesla model S (manu. 3/2017) which came with standard audio. It has hw3 upgrade.
I had the nvx boost, and door speaker upgrades but was still unhappy with the audio (that’s for sale if anyone wants it) So, I upgraded to the following.
Front dash speakers: infinity kappa 303s
Front tweeters: infinity kappa 603cf tweeter
Front door drivers: infinity kappa 603cf 6.5 driver
Rear drivers: infinity kappa 62ix 6.5” 2 way coaxial
Amplifier/dsp: Audiocontrol d-5.1300
Subwoofer: alpine type R 12” in vented box
I also mounted an iPad under the the MCU and I’m running TB3 with in-line DAC to RCA directly to the amp. I play lossless hi res or lossless tracks to the system this way and it think it sounds amazing with the dsp eq set to flat.
On the ipad, the eq is off, Dolby atmos is off, sound check is off.
Question 1:
For those of you out there with DSPs, do you set the signal delay/timing correction for each speaker or speaker group? If so, what settings are you using?
Question 2:
I got a dsp because I thought I could use the sound coming from the mcu, and counteract all of the things we don’t like. (Ie. Bass drop off etc). Has anyone gotten their sound signal coming from the mcu to sound good using the dsp? If so, can you show your dsp eq settings?
Question 1:
Question 2:
