Tesla Model S/Model X Battery Data
Discussion in 'Battery Discussion' started by M67v, Feb 25, 2016.
Tags:
  1. M67v
    M67v #1 Model S fan
    Reading, PA
    I was bored and started collecting data for the different battery packs and got some interesting results.
    In conclusion, I think Tesla should make their batteries more efficient in terms of range.
  2. Sad
    Sad Member
    Switzerland
    It seems you used range numbers for the model S 90kWh cars that are identical to their 85kWh counterparts, they should be 6% higher (I believe Tesla now advertises them on the website)
  3. M67v
    M67v #1 Model S fan
    Reading, PA
    The EPA got the same range.
  4. Sad
    Sad Member
    Switzerland
    Yes, but it's incorrect, taken directly from the 85 models (not sure why)
  5. jerry33
    Texas
    My understanding is that the change was too minor to require a new (costly) test.
  6. rabar10
    rabar10 Model 3 >> Focus Electric
    Indianapolis, IN
    Looks like the Y-axis labels on the Power to Range charts are flipped... PxxD cars will have more Horsepower per range (miles), not the other way around.
  7. jbcarioca
    jbcarioca Active Member
    The 90's were not tested, as Tesla reported. Therefore, they have identical stated range as do the 85 equivalents even though they have a minimum of ~ 5.8% better. In reality the anode change in the 90's may well have superior charge retention characteristics also, so discharge may be slightly less wasteful (i.e. less waste heat generated during discharge). Unless they actually show the comparable tests if the two pack sizes vs drivetrain we will not know precisely what improvement there is. user tests thus far have not been sufficiently controlled a/b to be both precise and accurate, as i understand it. Still I'd much rather have the new anode than the old one.
  8. M67v
    M67v #1 Model S fan
    Reading, PA
    Look closely...
