Actually it’s not very complicated. Compressor, valve block, reserve tank, and each individual strut. That’s it. Compressor and block are the same as Jeep, Audi, etc.
Plenty of threads on this from me, BostonBurley, Aggmeister, GTech, etc.
Very easy to check for leaks. Remove the frunk. Check pressure at the reserve tank. Spray soapy water on the compressor and block Voss connectors and see if bubbles come up. However, as your front end is slammed and it ran for 12hrs, your compressor needs replacing. Not sure why it ran for 12hrs because it should’ve therm-tripped well before that. The block is cheap and the system is depressurized when replacing the compressor so is cheap insurance, but certainly not necessary.
The SC has a high success rate at fixing. People are golden after compressor swap, which is the bulk of the issues. Sure, there are reports of actual leaks, like air lines having micro holes due to rubbing, but again, you can self diagnose that.
Don’t get me wrong… I hated spending the $$ to replace the compressor, especially after multiple attempts with aftermarket parts, but my point is that it’s an “easy” fix, albeit an expensive one.
