Adamas has also picked up on the "no-rare-earths" point, but they don't really add anything to the discussion.
A thought that I had was that there may be learning going on from the Semi, and that this learning may be propogating to the Gen3 and perhaps also to the Cybertruck. If you recall the Semi has some clutches that disengage motors so that there is no motor drag. The clutches are nifty in that they are essentially a dog tooth clutch that engages two shafts spinning at matched speeds (maybe even matched positions, we don't yet know that bit) before carrying out the engage/disengage operation. So transient forces are minimised, and there are no friction/wear components. Great if it works reliably.
The steady state power (or torque) requirements in a vehicle are relatively low. It is really the acceleration requirements that call for the big motor. So perhaps the Gen3 will be multi-motor in nature with a ferrite 'weak' motor for cruising, and a clutched neo 'strong' motor for boosting (acceleration, hill climbing, maybe even regen braking). That would allow for the use of ferrites with the existing ferrite field strengths (i.e. no magic ferrite2). Since the duty cycle of the neo would be relatively infrequent then they might be able to get away with a relatively skimpy neo boost motor & ancilliary systems. This may show up first in the CT.
Just a thought. I guess we will find out more in due course.
Anyway here is the Adamas bit :
Implications: Tesla Announces Next Generation Rare-Earth-Free PMSM
