Yes, when I have tried to use time-based control mode this does seem to be what the Tesla algorithm does. One sunny day, and then the darn thing won't charge from grid until 3 days later. This is useless in the UK, since my solar generation can vary by 15kWh from one day to the next.In my experience if we have a sunny day it assumes the next three days will be sunny. In other words it looks at the previous three days and assumes the best solar production in that period for the current days solar forecast. Has anyone else observed a similar behaviour?
I’m on iOS but the only change appears to be the version number. I’m trying at the moment to set up a raspberry pi so that I can automate goi g to backup mode during off peak times.Sorry you're still having troubleGdotp. I'm still controlling mine manually during the night......
How did you get the updated version of the app (4.2)? I've been to the Playstore but it only shows the current version that I already have......
Heidi who? I’m going to start to contact Tesla on this as the more pressure we can put on them to address this the better.I'm going to have another go at Heidi tomorrow, pointing her to this thread, and asking if she can let me have an address in the USA to email.
Of course.@ Gdotp
I'm sure it would be beyond me on my own, but I have technically-expert friends who might be able to help - would you perhaps be able please to post what I assume is a link to the Youtube video you mention, which again I assume tells one how to do this....?
Interesting, my approach using scripts on RPi and self-powered mode is only giving 1.7kW charge rate and I had not come across GilbertSolar. At a glance at the code it looks like it only changes backup reserve percentage while staying in current mode. What mode you are running in @Gdotp time-based control or self powered? The app will show which mode is currently selected.BTW it worked last night charging from zero to full in my off peak period at a rate of 3.4kw .
Also I wonder what setting backup reserve percentage to less than 100% but more than currently stored does while in time-based control mode? I'm half remembering it does nothing and thinking "100%" is a magic number.
I so wish there were common terms!
time-based control mode (app) = "autonomous" (API)
self-powered mode (app) = "self_consumption" (API)
EDIT: Ah ha the GilbertSolar script uses "tou" and "backup" as parameters meaning 0% or 100%
I hope not! It did start charging the second the script ran and when I tested it earlier in the day it started immediately and stopped immediately so I’m hopeful. I’ll report back on tne next few days of usage.@Gdotp I am also wondering if your experience of changing from zero to full in the off peak period at a rate of 3.4kw was a fluke. The scripts you use were written to prevent the Powerwall from discharging, and so the fact it charged and the rate could be because the Tesla algorithm decided from previous days data to do that last night. I am assuming you are in time-based control mode. Could you report on how things go on subsequent nights, especially if you get some solar some days. I hope it all works out.
I also wonder if charge rate behaviour depends on firmware version, could you say what version you are on now?
Thanks @Gdotp, same firmware version here, I look forwards to hearing your experiences with interest.I hope not! It did start charging the second the script ran and when I tested it earlier in the day it started immediately and stopped immediately so I’m hopeful. I’ll report back on the next few days of usage.
Good to know @mw963 . Out of interest how low was the battery when you started charging? Did it have more off-peak time than it used, or was that higher charge rate the only way to get to the backup reserve percentage that you set in the cheap energy time period?In self-powered mode it charges at 1.7 kW, however for the last two nights using TBC mode it did what Gdotp's does, and charged at 5.0 kW for about an hour and a half, then dropped to 3 kW for a few minutes before stopping when fully charged. I thought that 5 kW shortened the life of the battery and was only used exceptionally.....
