The temperature indicator shows high temperature after charging
Discussion in 'Model S: Battery & Charging' started by Msolomi, Dec 3, 2014.
  1. Msolomi
    Msolomi Member
    Atlanta
    I just noticed that the thermostat goes up anywhere from 83-91 degrees after my car is done charging. This is the temperature range I notice as soon as I unplug the charge either after immediately completing the charge or interrupting a charge. Is anyone else noticing this?
  2. andrewket
    andrewket Well-Known Member
    Are you referring to the external temperature gauge? And I assume you mean it's indicating somewhere between 83-91, and not increasing by 83-91 degrees :)
  3. widodh
    widodh Model S 85kWh
    Middelburg, The Netherlands
    I've seen the same multiple times. Mine is set to Celcius (EU), but seeing 32C is not weird after charging.
    Some of the heat produced by charging goes by the sensor I guess.
  4. Msolomi
    Msolomi Member
    Atlanta
    Correct, I'm talking about the external temperature gauge. After charging, if it is 61degrees outside, it will show about 85 immediately after charging and then it drops. Not sure if this is normal or not.
  5. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I'm not sure where on the car the temp sensor for the temp display (on the center screen) is located but my guess is that the radiator fan for the battery cooling system is blowing warm air onto the temp sensor, resulting in the temp increase you are noticing.
    You could ask you local Tesla Service Center about it and see what they say.
    I have not noticed what you describe, but then I haven't looked for it.
  6. bob_p
    bob_p Active Member
    I've noticed the same issue - outside temperature was in the 50s - but the car, inside the garage, while charging was in the 90s.
    Overnight, when charging has been completed for several hours, the inside temperature is pretty accurate.
    NOTE that this problem has been present in my ICEs with exterior temperature displays - they often didn't register the correct temperature, especially after the car has been sitting immediately after driving, when the engine heat warms up the car until everything cools down.
    My bigger disappointment is about the temperature setting on the climate controls. In order to get the car cooled properly, it typically requires setting the climate controls to 67; but when heat is needed, I manually increase the temperature to the low-to-mid 70s.
    Based on the outside temperature, I wonder if a software setting could be provided to correct for this and properly calibrate the climate control temperatures to be more reasonable...
