The Unofficial Aftermarket Air Suspension Thread
anyone else have a kill switch installed? i have mine tapped into the front 12v and the management stays on, so we had install a kill switch in the cigarette lighter in the armrest.
does anyone know if the management will eventually turn off on its own when the car goes to sleep? or will it stay on and constantly drain the battery?
If wired properly, the management will turn off after a bit. There should be a wire from the management that goes to a "switched" 12v location somewhere inside the cabin. The management uses that signal to turn on/off.
I have a leak coming from the top of my front airtekk strut. Does anybody know if there’s a easy way to fix this type of leak?
Stole these from my roommate. 3LR on Air Lift bags + Rotiform ZMOs. Sadly he sold the wheels before I could get my hands on them.
Looking into getting air suspension, I have read bad things about airdemand, and that universal air is the best setup with airlift management. However, is it worth getting the 3H 3P or 3S?
I haven't heard any bad things about airdemand personally, but can confirm that UAS is superior to Airtekk. I would avoid Airtekk at all costs.
You want either 3H/3P since those systems will keep your car at about the same exact ride height when ever your air up. This will save your tires in the long run since changing the height of the car messes up the alignment.
Anyone here bagged the new 2022 Model 3 yet. I pre-ordered my M3 and it should be here by summer. I heard the frunk is a little smaller then tthe2021. I've bagged a few vehicles so I know what I'm doing. I've bagged my personal one which is a 2014 Honda Pilot SUV with Accuair eLevel. I have my air management already for my M3 which is Accuair eLevel+ 3 gallon VT tank dual Viair 485c and UAS bags from Universal Air Suspension . My SUV for attention.
