The Unofficial Aftermarket Air Suspension Thread
Getns, I am having some significant rattling coming from the rear suspension. It started after about 1k miles after the suspension install. For sure coming from the rear wheel well area. These rubber bushing were not installed and I noticed on a video that someone stated that they should in order to prevent noise. What do you guys think?
The top rubber/plastic insulators don't fit on the UAS bags. They do on the Air Demands. I had noise in the rear at one point and it ended up being the locking collars on the shocks!! Tighten those really good!!
Glad I found this thread! I’ll be new to “life on air” after my install May 9th!
I did have one question for those that have been on air for a while.
Are there any other upgrades that are recommended from experience? I’ve heard toe/rear camber (to reduce tire wear, alignment, ride, etc.) and End Links (tend break) upgrades are recommended as well. Being that my Model 3 RWD is a 2022, I’m going to ride out the stock cambers and end links but open to any feedback and/or other upgrades I should consider. Doing it right the first time is definitely my take on this decision!!!
Welcome!! Just the rear camber arms. You should have enough factory toe adjustment. I have the front MPP A-arms and with even an extra shim it's not enough to get any positive camber back,
Have your stock ‘End Links’ been an issue or are these usually changed out with a sway bar install as well? Appreciate your feedback! I’m definitely getting rear cambers with my air suspension.
Finally got the look I’ve been wanting for awhile now.
My buddy's 2021 Model Y. Accuair e-level management, Universal Air Suspension Solution Series struts and bags, 5 gallon Accuair Endo VT, dual Viair 485C Compressors. 21x10 AG wheels.
Reactions: Dave EV
I was gonna install my friend's system in the trunk, on his Model Y, but his Accuair VT 5 gallon tank was too big to fit in the lower compartment. A 3gallon would of fit perfectly. There is a company Sadistic Iron Works they specialize in high end air suspension installs they had a Mock up on a Model Y.
