darth_vad3r
Well-Known Sith
@Rocky_H this was in the OP:
OP’s thoughts coming in (pre-ownership) were tainted by wrong information:
120V = 2-3 mph (wrong info)
5-20 = 5-6 mph and “may just work fine for my situation”
14-50 = 30-35 mph
Reality is that 120V is 5mph and at zero cost may have just worked fine for the situation.
Knowing this ahead of time can influence people’s decisions as to whether to install charging equipment or not. 5 vs 3 is a massive difference and could affect decisions for a lot of common short daily commute distances.
12h x 3 = 36 rated miles
12h x 5 = 60 rated miles
Anyone with a commute that is projected to take 36-60 rated miles might dismiss 120V as a viable option when, in fact, it is totally viable for zero cost, and you can “trial” it for free and change your mind later.
I drive 44 real miles/day, and charging at 120V is completely sufficient for me. OP is only driving 40.
Not sure what the average commute is, but I feel like 25-42 miles might be pretty common, and that’s nerfing the 12hr charge add range of 36-60 by a full 30% to account for bad weather.
I'll be getting my LR AWD M3 in a couple of weeks and from what I've been reading I've been looking at three different home charging options. My daily driving during the week will be around 40 miles per day. Of course, the first option is to stick with the basic 120V house plug in that probably gets about 2-3 mrph. Second option is to convert one of the regular garage outlets into a 5-20 NEMA outlet (20A circuit, so 80% would be 16A) which probably gets me around 5-6 mrph and, even though I haven't got an estimate for that option, I am guessing it's probably no more than $100. The third option would be the 14-50 NEMA outlet, probably 30-35 mrph, and I received an estimate for this option at around $700. So, even though I'm hearing good things about having a 14-50 NEMA installed in garages I'm thinking the 5-20 NEMA outlet may work just fine for my situation. Any other pros or cons in converting a regular 120V garage outlet into a 120V 5-20 NEMA outlet? Appreciate any info or advice for those in the know. Thanks!
14-50 = 30-35 mph
