Definitely no magic cars here. I think I'm at 172 lifetime. Mostly highway but heavily varied (all leisure/trips/errands, no consistent commute). Granted only 1300 miles total so far.
Here is a curiosity, I have yet to experience. How much does cold temps, say 30degs vs 70, have on efficiency if you DO NOT USE climate control at all? Is it that much of a hit just for a cold battery? Is it 5wh/mi or 40wh/mi? I never really understood the need for heat in a car. (I hardly used it in my ice even though it was free) You should already be dressed for the elements, and in a car you are out of the wind so its warmer to begin with.
I don't expect my wh/mi to drop that much in winter except when accommodating those picky passengers.
You don’t need to “dress for the elements” if you travel from home to work, parking inside a garage at home and a parkade at work. Kinda like saying why heat your house or your workplace when you can just dress for the elements. If you are not spending any time outside, or just 5 seconds to enter your car, you don’t need to wear a snowsuit or parka
I noticed around ~8-16 Wh/mi (5-10 Wh/km) improvement going from mildly cool spring temperatures like 59-68°F (15-20°C) to warmer temps like 77-86°F (25-30°C).
What are your winter temps like? You may be surprised by the efficiency hit, even if you don’t use heat. I would expect a further loss of efficiency going to near freezing vs the cool spring temps that I saw the higher consumption in. I’d guess another 15 Wh/km even without cabin heat. So say around 40 Wh/mi.
Also don’t discount the fact that even if you “didn’t use heat” in your ICE, your cabin temperature still benefited from those thousands of explosions in the motor giving off a ton of heat
If the temperature drops low enough, the car will heat the battery, even if you don’t want the cabin heated ... so that will cost you further efficiency as well. You’re probably getting to > 40 Wh/mi hit at that point.
I’m expecting my range to get hacked by at least 25-30% for winter.
