ucmndd
Providing evidence to support one’s feelings doesn’t seem to be particularly important to this individual.Can you point me to those?
So can your Tesla. It’s called the Energy app. Have you ever used it?My friends 2003 Suburban can predict range based on previous driving.
Again, as could your Tesla. Have you ever used the energy app? It’s remarkably accurate.. In 2017, A Better Route Planner could accurately predict range based on weather, road type, speed and elevation. This isn’t that hard.
I understand perfectly why to never use the mile estimate in that way. In winter I drive with 75-80% efficiency most of the time (drive 80 miles and use 100 miles of “Tesla’s system range”).I just charged to 100% Monday morning before taking a trip. The range showed 323 miles. The trip was 130 miles and showed 47% battery remaining, so I charged to 75% for the trip home. When I got home, it was at 5%, so 260 miles on ~130% charge. What this shows is that you should never go off the milage estimate and just use percentage, like you would a gas gauge.
We really know, and it is really degradation of the BMS capacity estimate, and has real-world impact on achievable range.nobody really knows but probably is at least partially due to real degradation.
As @AlanSubie4Life said above me, this is completely normal. All Teslas lose about 5-10% of their original reported range in the first year or so. The battery packs are made up of thousands of individual cells. Initial range, as reported, can be skewed a bit. So some cars start with a little more real range and some start with a little less and some degrade a little bit more. After this initial degradation, things normalize and the battery degrades very slowly (years or maybe even decades), if you take care of it.I understand perfectly why to never use the mile estimate in that way. In winter I drive with 75-80% efficiency most of the time (drive 80 miles and use 100 miles of “Tesla’s system range”).
That said, the reason I started this thread is that maximum “Tesla system range” used to be 330 last winter and this winter it’s more like 315-320 under same conditions at full charge.
So was curious if that was really degradation since my car isn’t that old and plenty of cars with less miles have >320 miles at full charge according to TeslaFi and anecdotal accounts.
I think the answer is nobody really knows but probably is at least partially due to real degradation.
This will be my last post on this thread. I know there is a lot of white noise now but the advice I gave above is sound. A good, non-hypertechnical set of guidelines to follow to get a long life out of your battery.Easy rules to follow:
Avoid charging above 90%. New Caveat: Every time you do, you degrade the battery more rapidly than if you keep the charge limit around 45-75%.
(The individual batteries create dead lithium "dendrites" and once they are dead, they can't be reversed. This happens in all lithium-based batteries to varying degrees. The higher and faster you charge the battery, the more of these will form.)
Daily charge (if you want to keep the car for 8+ years) you would keep your daily limit at or below 80% and preferably you would keep the charge between 45-75% most of the time. (for the same reason as above)
Discharging too low isn't a huge deal so generally, discharging to 5% is fine on occasion. Just wouldn’t recommend keeping it unplugged and below 20% for long periods of time (new caveat: leaving it below 20% prevents sentry and preconditioning. Also, if it gets cold or you check the app/open the doors frequently it will eventually drain after a few days).
Supercharging degrades that battery faster than home charging. But not enough that you should avoid road trips.
(Battery charge rates are expressed with "C", that's the rate that it would take to charge the battery to full in one hour. So, if you charge the battery from 0%-100% in 30min, that means you charged the battery at 2C. 2x its capacity. For lithium batteries you want this number to typically be below 1C, but newer batteries and better cooling systems allow for faster charging with less degradation)
Also, some degradation is unavoidable. In the first year, all Teslas lose about 5-10% of their initial range. This is normal. But if you just keep the battery below 90% and only supercharge when you need to, you’ll have a good long life with your battery.
For me personally, I found about 5 years ago that switching to percentage from range in miles made a huge difference. The range in miles displayed in the app and on your screen is a made up marketing number and in no way reflects the actual range of the car in that moment. Your real world range is (almost) always lower than the reported range in the car/app.
There are also other tools out there like TezLab that will display your real world range in real time, this can be a better way for you to understand your true range in a given situation. However, with any EV, there are tons of factors that play into the acutal range you get (weather, hills, road surface, tire pressure, etc), it will never be perfect.
