Knowing the algorithm doesn’t change how it is divorced from reality. If the car always multiplies a fixed kwh/mi x battery percentage + 4.5% how is this number suited for measuring battery degradation? If the percentage is always multiplied by the same nominal consumption?
There is ways to calculate the bsttery capacity by your self.
I did it with the old car and drove from 100 to zero (described in the other post).
It matched.
I did it on my MSP, as it started with a nominal full pack of 95.7 which sounded wrong. The numbers hit 98-98.2 kWh, and the car/BMS also eventually hit 98-98.2 kWh.
(I have described the capacity calc in a few posts here on TMC.)
We can calculate the capacity (done that - it matches) and we can perform a drive to test the outputed energy (done that, it’s a match). The BMS can be off from time to time, but the car actually tries to know the real battery capacity and the displayed range is a true split of the energy in the battery.
There is no faul play in this, really.
The chart in the study shows as percentage of the reported range in miles. Using this logic, the reported range should always be the same at the same percentage.
No, as the capacity estimate changes from time to time (also depending on that the battery capacity actually can go slightly up, not only down), the range displayed is (nominal remaining -buffer)/ the constant.
A lower capacity means that 100% SOC will be less energy, hemce each percent will be a shorter range.
There is no bull with the SOC either.
SOC is straightforward, displayed range is also.
Lastly, the entire methodology of the study is flawed.
I guess you are talking about the fast charge / supercharging study?
I think you and I are quite agreeing about the fast charging degradation. I did not read all the posts bit my personal view is that it wears, and probably much more than that study shows.
It might be that the capacity do not go down very much but if supercharging or fastcharging much enough / to often, one day the lithium plating cause a short in one or more cells and than we have a problem.
I know of a swedish M3P mostly supercharged (~55 or 60 MWh supercharging), that killed the battery with what seemed about 12% degradation (SMT used so capacity wise). My take from that was that the lithium plating from extensive supercharging did it.
