Car: Aug 2016, AP1 MX; Software: 2019.32.12.3 1b89dd1
A forum search showed some MS owners having problems with the car not recognizing TPMS sensors of new tires, but my issue is a little different.
Immediately after the update to 2019.32.12.3, I get a continuous "Tire Pressure Monitoring System Failure" warning on the instrument cluster. On some trips, only one sensor shows up with no reading, but on other trips, all four sensors show no reading. The timing of the firmware update, plus the failed readings on multiple wheels leads me to believe these are related. These are the original TPMS sensors that came with the car and have been working fine until last week. The warning message is not a low pressure warning, and at 44 psi, all tires are above the 42 psi spec.
I will have my SC look at this next month when I go in for my 50,000 mile maintenance. But, I wanted to ask the forum group if anyone else is seeing this, or is this a specific problem with my car, and unrelated to the firmware update?
Thanks.
Thanks.
