Yay. As predicted to the day…
Seriously though, I do have one tyre behaving a little like OP is describing. TeslaFi is showing a sudden change in that tyres pressure a few minutes into the drive after which everything stabilises and all is good again. I suspect that that is the point that TPMS gets its first true readings but it’s a bit more nuanced than that.
I think the change is that previously would show no pressure reading at start of a drive until it got its first updates, but now it displays the last pressure readings previously recorded, ie potentially from previous drive. Hence sudden jump between initial stale readings and fresh readings for the drive.
RR increase 1psi in space of a minute. Return leg of two very short drives. Out leg was stable and approx 10 mins before. (time top to bottom).
And out leg 10 mins before
