Yes, but I don't think the app or in-car let you set the car to less than 50% desired charge.is it possible to Trickle charge over winter (not driving just letting Tesla model s sit)? like just plug in wall outlet set car at something like 20% charge and leave it outside?
Protecting them from rain and snow would eliminate most of the rust. I'd imagine someone sells wheel pants/covers for this purpose.would brakes rust if covered from rain snow with boards or general moisture makes them still rust?
There is no battery heating taking place in the Tesla vehicle while parked. There is some battery warming while charging but that will be minimal only as needed to bring the battery charge back to 50% after the state of charge drops a few percent.well this is a 2015 s. are rodents attracted to heat of battery or just shelter?
Energy consumption would be 5 to 6 kWh per 24 hours (this would cost ~$1.00 per day or more depending on utility rates)
Depending on your local electric utility rate, yes. $1.00 US would approximately be the cost of leaving Sentry mode turned on 24 hours. It is not Sentry mode that consumes all of the energy. It is the Tesla Model Y remaining in Standby mode while Sentry mode is active that would run up the utility bill. Set Sentry mode to be Off at the parked location (assume Home location.) The Tesla vehicle will still lock, the Tesla vehicle alarm system would be active while the Tesla Model Y is parked, in Sleep mode. Power consumption in Standby mode ~ 230W continuous; consumption in Sleep mode ~25W. (about 1/10th as much as Standby mode.)So you are saying to keep it charged at 50% would cost $1.00 a day?
Many Tesla owners in Hawaii are part time residents. On the Big Island of Hawaii, standard residential electrical rates currently average $0.48/kWh. 0.23 kWh x 24 h/d = ~ $2.65/d. TOU electrical rates vary considerably. If you have solar, your electrical utility cost would be less or even zero but that doesn't count the cost of the solar installation and equipment.Depending on your local electric utility rate, yes. $1.00 US would approximately be the cost of leaving Sentry mode turned on 24 hours. It is not Sentry mode that consumes all of the energy. It is the Tesla Model Y remaining in Standby mode while Sentry mode is active that would run up the utility bill. Set Sentry mode to be Off at the parked location (assume Home location.) The Tesla vehicle will still lock, the Tesla vehicle alarm system would be active while the Tesla Model Y is parked, in Sleep mode. Power consumption in Standby mode ~ 230W continuous; consumption in Sleep mode ~25W. (about 1/10th as much as Standby mode.)
