I do really miss the Trip Info card as I was almost constantly monitoring my power usage. The tire pressure card was also useful, but I do not miss it as much as I miss the Trip Info card.
Both trip info and tire pressure are now accessible by voice command (2022.12.3.12). I find that technique preferable to touching the screen, regardless of how many taps are needed.
Yes, I really miss it. Used to use it all the time to monitor efficiency. But, like a lot of things 'Tesla', it was just too good and convenient to have a lasting place in the UI...
No, not what I said. What I said was that I find the voice command better than touching the screen even once. I only glance at the trips quickly, so it doesn't matter to me in that it blocks the map. I return to map by voice command.
ah, got it. I haven't tried using voice to open the trip screen (or to close it.) When they first came out with V11 there was no voice command for it but I just updated to 2022.12.3.20 so I may be able to use a voice command now.
The problem with voice commands is they are poorly documented, inconsistent, have been removed in the past and don't universally work. They're a nice adjunct but in no way a substitute for a decent interface.
They need to put the tire pressure back where it's not hidden. Every other car that has TPMS has a way of setting a display to show pressure without obstructing everything else. And it does not work with voice command, which makes no sense at all.
