So...I'm on driver's handle #3 or #4 at 106k miles. Last one was replaced at 96k miles (in April), so even though I'm technically out of warranty my plan B is to take it back to Tesla Service and hope their response isn't "failure after 5 months is expected, so sorry".
The issue is that the handle presents normally and can be pulled the last ~5% normally, and that last 5% lowers the driver's window but unfortunately does NOT unlatch the door. This started as intermittent a few weeks ago but is now permanent.
Being a competent car guy, Plan A was to save everyone some time and hassle and fix the problem myself. Easy peasy, its the microswitches, of course. Unfortunately, after pulling the handle out it is obvious--both visually and confirmed with continuity checks--that all three microswitches function properly.
Any thoughts on what's next, including what I may have missed? Everything I can find talks about physics damage, of which I find no evidence. I see a location adjuster on the aft switch, but I'm fairly certain that one is what stops the handle at ~95% extension and it seems to work fine. The forward switch is the one that engages at full pull, and since the window comes down a bit like normal I kind of think all is functioning properly with that one too.
Does anyone know of door latch problems? I didn't have time to pull it out and inspect, but I guess there's a chance something there is wonky? I'm exclusively opening the door with the inside handle, which of course mechanically activates the latch via the cable.
Thanks for your time!
