I have seen this before on my Nissan Xterra many years ago. That time, the gas struts need to be replaced and were no longer holding up the hatch. It didn’t have auto open or close but it won’t stay up when it is cold outside.
Are you familiar with feature that lets you set the hatch open height by manually moving it to the height you want then holding down the hatch button until it beeps? I’d try that - should reset the target open position. Just a guess, no guarantee...
Right there, when it makes those 3 beeps and starts to close, press the close button to stop the movement. Then close/open normally using the fob or the hatch physical buttons.
Gas strut.
Easy to verify;
When it opens, help it by lifting manually about 2-4kg of thrust, help it holding position when it is fully open, observe that it will stay there.
Then, stop helping... Overload will be sensed, and it will close.
Gas strut.
Easy to verify;
I tried. It stayed in position. But as soon i restart the operation, same situation, 3 beeps and automatically closes. I start thinking the Gas struts are broken ....
What was the resolution on this? I've been working for or more years with Tesla on this, they've replaced the struts, latch, everything and it still does it. Works fin on flat gorund, but the gentle slop eof my driveway (2-3% maybe) causes it to fail.
