Electric700
Batteries are net power consumers.
If your Solar PV put out 50kWh on a good solar day, if you put them through batteries, the result is usable maybe 45kWh. you spend kWh by storing them. It's well know and sales should always be telling this. Batteries do not store the input electrons, they undergo a chemical reaction causing the electrons to move between Cathode and Anode. So, there are charging losses. Also, EVs undergo similar losses during charge. You may use 80kWh to charge a car and only be able to use 72kWh out of those.
If you charge batteries from the grid or solar PV all the time and they are used only for backup, you will spend a little money keeping them topped up, but not that much (they should not cycle much, they are Li-Ion and not Lead Acid which need topping up).
I think the only reason to use PowerWalls is if you really MUST have standby power and make sure you don't spend kWh doing so. And also if you are in CA and arbitraging the peak power load prices of a variable rate plan with super-peak prices in the afternoons.
Solar and batteries are a solution, but not an economic one.
Bonaire, with Powerwalls you can run off of the solar energy at night that you generated during the day, and if you produce enough solar energy, you can also shift power in the daytime during peak periods. In addition SolarInAZ mentioned he has a gas furnace. In the future he could get a heat pump and run everything off of an expanded solar array (or possibly wind power once Tesla adds that capability). This would further lower costs. If it were me I would see what I could do to keep the Powerwalls.
