I have been lamenting the small size of my solar system ever since I got my first EV. When I had the house built in 2012, I wanted to go for the New Solar Homes Program and get a 9+kW solar system funded by a huge State rebate. Unfortunately, the solar installer I picked during construction was not up to the paperwork requirements and I had to scale back the solar to something I could afford without the NSHP rebate. Anyway, now we're coming up on 7 years in the house and for the last 4+ years we have had two EVs and paid approximately $1000 to PG&E at true-up in those years.
Since the solar system is old, we are on NEM 1.0 which has no Non-Bypassable Charges. The Tariff states that repairs or upgrades must remain less than 10% or 1kW (whichever is larger) greater than the original interconnected system in order to remain on the NEM 1 tariff. The calculation is based on the "rated generating capacity". I have found out that this is calculated by multiplying the panel's PTC Rating by the Inverter CEC Efficiency rating. I have 18 Motech 240W panels on Enphase M215 microinverters. So, I get 18 x 0.240 x 0.96 = 4.15kW Rated Generating Capacity (rounded up to nearest 10W). I have not had any Enphase failures, so I'm not inclined to change them. So, I'm thinking I should replace some or all of the panels. The problem is that I can only go 5.15kW Rated Generating Capacity. This results in 298W PTC rated panels, if I change them all. I don't think I could use 300W panels because it would technically be over the limit unless I just leave one old panel up there. Also, it would be a 1.376:1 DC-AC ratio, so there would be some clipping. The arrays face SE and SW.
Thoughts?
Pic for reference.
Thoughts?
Pic for reference.
