AmpedRealtor
It closes after you leave, but only if you open it using the Homelink button in your vehicle. That is, you can't open the garage door with the wall button, then expect the car to close it. You have to get in the car, open it, and then after backing out it should work.
I open the garage door from the wall button (otherwise I can't get around to the driverside of the car), and it auto closes when I get to the spot on the driveway where I set the homelink position.
Did you reset the homelink position after updating. It may be necessary fore the auto close to work.
My vehicle exhibits the same behavior as ohmman's. If I open the garage before entering the car, auto-close never activates. I must open the garage using the vehicle control, only then does it auto-close.
