darth_vad3r
Well-Known Sith
It's quicker to turn the whole thing off and on. Just hold fan for off and tap for on. Feels a whole lot longer than 30s.
Also many times in the morning, I don't need to turn it on at all. I turn it on when I feel I need it.
Easier to confirm by ear that it's completely off too.
Sure, it's one tap quicker, about the same amount of time. Long press to turn off everything vs tap once, then tap "A/C" to turn A/C off.
But my secondary point was if you turn A/C off a few minutes before your drive ends you can avoid mildew build up from moisture as well as having the compressor off when you stop the car and next get into it. Just the fan is on. If you really don't want the fan on either next time you get in you can turn that off as well. I find I almost never drive with no airflow at all of some sort on, whether it's no A/C outside air on low fan setting, or A/C on recirculate or auto, or heat... the only time I turn the whole system off is occasionally when I park ... even then I don't even really know what I'm trying to accomplish ... save a couple Wh before I get out and lock the car? LOL.
