Water leak inside the Trunk
I see a water leak inside the trunk and it’s coming out of those door stopper or adjusters (I don’t know what it’s called). The car is only 4 weeks old. Anyone come across something like this. I am sure the SC is going to make me run around before they figure out the issue
See this thread, it sounds like a number of us with recently received vehicles are having the same issue. Getting Tesla to acknowledge and fix has been painful.
Reactions: anapon
thanks.. i have an appointment tomorrow. i will talk to the SA after dropping the car. i am going to show him the issue. they are like robots.. they dont listen at all.. i believe my issue is this one. I am going to ask them to look at the below fix. my car only 4 weeks old. austin build.
Performed water test and water present in tailgate. Removed tailgate trim and performed test for leakage . Found seams behind tailgate lamps leaking. Sealed body seams and reinstalled tail lamps (inner) . Retested and no leakage detected. cleaned water from tailgate area. Verified Proper Sealing.
Correction: General Diagnosis
Correction: Clean Up Water Ingress
Correction: Exterior Component/Panel/Glass Adjustment - 0.6"
Quick update for those suffering from this issue. Tesla released a service bulletin that should take care of the problem in just 1 visit to the SC! I hope this helps some of you get quick resolution of the problem.
  • SB-23-10-003_Reseal_Liftgate_Assembly_to_Prevent_Water_Ingress_R2.pdf
Reactions: Stach and anapon
