It just dawned on me... Can you even use a 5th wheel with the CT? Thinking about it's design and the entire bottom being battery packs, I can't imagine it being easy to get to the points you'd need to in order to bolt down a 5th wheel attachment and my searches have found nothing on being able to get one. That said, I've never had a need to do a 5th wheel tow. Is there any disadvantages to not being able to use a 5th wheel with the CT? I know you can get a trailer large enough to potentially have 11k lb weight when filled and still be able to tow it with a tow ball (though I believe you are starting to push the limits of a standard tow hitch when you are at that weight as now you are putting 1500lbs or so on the tow ball). Maybe there is no reason to need the ability to add a 5th wheel to a CT with it's current specs?
