You got jacked!According to my app. They are nowhere to be found!
There's no problem until the app shows cinder blocks under the car...I think there is a problem. I just don’t know what!
Who knows! It could happens when I’m sleeping!Are you sure Santa did not take your car and is using it as a flying reindeer cart?
"vehicle_config": {
"wheel_type": "AeroTurbine20"
The API returns a value which specifies which wheels you have.
This is mine, for example.
Code:"vehicle_config": { "wheel_type": "AeroTurbine20" }
There's a chance that your config is missing or a value the app doesn't know how to display.
Oh, that would be cool to see.OP are you on macOS/Linux? If so I can give you a command to dump your vehicle config if you want.
Yes, Tesla just installed my winter tires. I will call them. ThanksYes, an adult in the room! OP, you didn't by chance have a different wheel set put on recently did you? You may or may not know this, but if/when a mobile technician or service center swaps out your wheels, this image should get updated with whatever version of Tesla wheels they put on. My winters are slipstreams and my summers are the original 19's, for example. So it seems there's an issue with this API call / config setting as Xtek says. I would either just wait and enjoy the bumpy ride or give Tesla a call. Hopefully you can get your wheels back for Xmas with the flip of a switch.
What does that mean? I don’t understand the term dump vehicle configuration.OP are you on macOS/Linux? If so I can give you a command to dump your vehicle config if you want.
My guess is that it means he knows how to "clear the cache" so to speak, thus hopefully cleaning up whatever cruft is causing your issue. But my guess is that since you just had your wheels swapped, that's the issue; that no new set of wheels were config'd properly.What does that mean? I don’t understand the term dump vehicle configuration.
