T TonyUsa Member Jan 9, 2020 43 1 Rancho Cucamonga, CA Feb 5, 2023 #1 Feb 5, 2023 #1 Hello, Where can I buy this door clips? Thank you, Tony
todd2fst4u Member Oct 26, 2019 403 342 Menlo Park, CA Feb 5, 2023 #2 Feb 5, 2023 #2 Rexka 15pcs Door Trim Retainer Clip Compatible with Tesla Model 3 1135147-00-B https://a.co/d/eFt9pBP Reactions: TonyUsa and MitchMitch
T TonyUsa Member Jan 9, 2020 43 1 Rancho Cucamonga, CA Feb 6, 2023 #3 Feb 6, 2023 #3 todd2fst4u said: Rexka 15pcs Door Trim Retainer Clip Compatible with Tesla Model 3 1135147-00-B https://a.co/d/eFt9pBP Click to expand... Thank you. Do you know how to remove the damage one out? Is it just slide out? Also, how does it fit compare to the OEM? Last edited: Feb 6, 2023
Adam3 Active Member Oct 4, 2015 1,201 1,562 USA Feb 6, 2023 #4 Feb 6, 2023 #4 The part that is still stuck in the door can be removed with a small flat blade screwdriver. There are two little tabs holding it in place. Reactions: TonyUsa
T TonyUsa Member Jan 9, 2020 43 1 Rancho Cucamonga, CA Feb 7, 2023 #5 Feb 7, 2023 #5 Adam3 said: The part that is still stuck in the door can be removed with a small flat blade screwdriver. There are two little tabs holding it in place. Click to expand... Thank you.
