What is the widest tires you can fit on the stock 21” Turbines? I found a set I’m looking to buy, they currently have 245/35/21 on them. It’s a square setup so I’m assuming they are a 8.5” wide rim? My car is a 2017 MS 75D. Thanks for any input.
Elevate your potential in all seasons with dry, wet, and snow control. Shop Pilot Sport All Season 4 tires from Michelin built with high-performance made to last.
www.michelinman.com
Plan on aftermarket wheels if you want more rubber in the back.
Keep in mind that the Turbines were available staggered as well (9" rear). If you want to go with wider tires would recommend finding a staggered set, I have run 275s on the 9" rear Turbine at one point.
As per above 255 is the widest recommended tire for an 8.5.
