Update: 2021 MYLR, 51 k miles.
1000 mile Pirelli Scorpion A/S Plus 3 255/50 X 19. Vehicle is at 51k miles, with Mountain Pass Performance Comfort Coilovers installed at around 10k miles.
Here are a few things to consider:
1) Aspect ratio 50 vs. 45: This size tire absorbs road imperfections much better than 255/45 X 19 tires. MUCH better.
2) Load rating 107 vs. 104: I thought the slightly higher load rating would have a stiffer sidewall, thus negating the change in aspect ratio.
3) These tires start at 11/32" tread vs. 10/32 and 9/32 (IIRC) for the ContiPros and the Michelin PilotSport A/s 4s.
However, because of the increased load rating, I can safely drop PSI to 36psi, vs. Tesla's recommended 42 psi.
So far, I like the ride of these tires MUCH more than the OEM-size Conti ProContact (30k miles) or the Michelin Pilot Sport A/S 4s (20k miles.), both requiring 42psi.
I don't push the handling characteristics very often. The tires seem to "float" more, which makes sense, but the car feels nicely planted at all times.
I'm baffled by the efficiency, because it seems to have IMPROVED over the OEM sized tires. This is probably because of perfect ambient temps of 50-70f, with minimal load on the HVAC.
(I might cross-post this entry in other tire comparison threads. I hope the moderator doesn't mind.)
