as of this morning i have had zero solar production. mobile app shows zero, connection via TEG shows zero, and display on the inverter shows zero.
I checked all the breakers, everything looks good. Powerwalls are on, solid green light, show 99% capacity.
I've got a big on/off dial/switch on my Delta inverter. Should I just try cycling that? Or is there a different procedure to try and restart/recycle my solar? (note- it's odd that the light for the power indicator is no on, but the digital display is on)
thank you!
thank you!
