I have seen those stories about the <100kWh as well.I think you mean 2019.12.1.2 but yes, it seems that all European superchargers are still limited to 120kW.
However, with this update some people with <100kWh batteries are seeing decent improvements due to ORBW alone, e.g. 116kW for a 90D
Also quite possibly the charging profile on 100D will be broadened by ORBW but have yet to test this for myself.
But what's ORBW?
I really want the 140~150kW SuperCharging on my 100D!
Just in time for our family trip to CH then. Would be nice! Although I fear that with my 75D, I won't be getting a lot more than the 92-93kW maximum that I've had so far (42.000 km). Which I haven't seen since a few months actually (went from 2018.50.8 to 2019.12.1.1).ORBW = On-Route Battery Warming, should be in your release notes, whereby the TMS [somewhat like Range-Mode] stops cooling the pack ~20min before arriving at a programmed SuC-stop, allowing it to heat to >40°C, thus enabling faster charging.
For 150kW I think we poor Euro-cousins must check back in like 3 months time -- a watched kettle never boils, you know?
ORBW, I see That's in 2019.12.2 indeed, but no mention of the higher SuperCharging speeds.ORBW = On-Route Battery Warming, should be in your release notes, whereby the TMS [somewhat like Range-Mode] stops cooling the pack ~20min before arriving at a programmed SuC-stop, allowing it to heat to >40°C, thus enabling faster charging.
Might it be possible that the European connector can't handle the higher Amps/Current?
They will need to push the current to something like 400A as you might be charging around 360V when the pack is on a low SoC.
This image was posted in a Dutch (NL) topic and that made me wonder.
The SuperCharger cabinet is rated at 400V 3-phase 192A, that's a maximum of 133kW input.
Let's say the chargers are 95% efficient, that would be 125kW of DC output.
How could Tesla upgrade this to 145 ~ 150kW without replacing any hardware?
Two posts in the Dutch section:
- Superchargers in Nederland (NL)
The maximum shown is 351A which is already more then the 330A.
At 0% SoC the 100D pack has 288V, so to charge it at 150kW would initially draw 521A
Mm, i'm not 100% sure but why should you have to match the pack voltage? Couldn't it just charge with 400V?
