What kind of performance loss is reasonably expected (if any) on a P85D using 19" wheels/tires compared to the 21"s? Specifically, I'm thinking of 0-60 times and the 1/4 mile.
Straight line performance (0-60 and 1/4 mile) is not noticably affected by the diameter of the tire. The real difference between tires would be on cornering and slalom performance. What would affect 0-60 time is the stickiness of the tire -- the softer and stickier the rubber, the less slippage and the better your launch will be. The traction control system will compensate, but it will slow you down. The Goodyears would be slower than the Primacys (speed rating is a pretty good analog for stickiness). I'd expect the 0-60 between Primacys and the stock 21s to be essentially identical. In fact, I believe that the 19 inch wheels are slightly lighter, so they might actually be a smidge faster.
100% agree. I would expect that a proper aftermarket 19" that has enough grip (aka something like my Michelin Pilot Sport A//S 3) would be slightly faster than the OEM 21s due to lighter wheels and less rotational mass and slightly less resistance (narrower contact patch). So from a purely technical perspective, less rotational mass = faster. It's not really noticeable though. Maybe something like 0.1s faster on a quarter mile.
There are many other benefits and reasons to choose 19s over 21s instead of trying to convince yourself with 0-60 or 1/4 mile times.
- Smoothness (you don't feel every bump on the road),
- quietness (you don't hear lots of road noise),
- much much longer tread life (2x-10x longer YMMV),
- safety - better for snow/wet weather (low profile summer performance are like ice skates in winter, do not drive them during winter!),
- they are less prone to blowouts or rim damage on potholes (due to larger sidewall that can absorb potholes without sustaining damage). therefore, no inconveniences with towing, rentals, etc as the MS doesn't carry a spare tire.
- COST (the tires are much cheaper [well, not so for my PS A/S 3], but still combine that cost with them lasting 2x-10x longer it is order of magnitudes cheaper over the vehicle's lifetime).
Frankly I went wider with 255s on my 19s so I do have a bit larger contact patch. I wanted all the benefits that I just listed without sacrificing handling (hard cornering).
After doing my research I chose the PS A/S 3 (
Pilot Sport A/S 3 | Michelin Tires ) due to all the exceptional reviews. After reading many many reviews on the tire they all seem to be in agreement and it has 4.5-5 star ratings everywhere from reviews and actual customers. It's an all season tire that outperforms summer tires. really best of all world's here. Here's one:
Michelin Puts Its New Pilot Sport A/S 3 To The Test | car News @ Top Speed
With exception to us southern-state dwellers, you need a set of tires that can handle the rain, snow and ice that the winter, fall and spring present us, and most summer tires simply can’t handle the elements. Well, Michelin has an all-new all-season tire that packs summer tire-like stickiness with an all-season design and features: the Pilot A/S 3.
This all-new Pilot Sport tire uses a special blend of silica to help enhance the "sticky" feeling of the tire and a tread design that helps jettison water from under your car’s footprint. The combination of water channeling and extra silica really helps the tire bite down on the road. Additionally, variable-thickness sipes on the outer section of the tread help break up the tension in the water and then lock together to create maximum rubber contact to the asphalt.
When it comes to tires, you cannot base purchasing decisions on sheer performance, unless you have tons of money to blow. You also have to consider how long the manufacture guarantees the tire will last. Most summer tires don’t include a mileage warranty and most all-season tires with any sort of warranty are too hard to perform well. Michelin obviously found a nice balance with the Pilot A/S 3,as these shoes come with a 45,000-mile warranty.
A truly unique feature on the A/S 3 that surprises even me - a seasoned expert in the tire industry - is Michelin’s Helio Compound, which helps the rubber retain its soft and sticky properties in cold temperatures. This is a frequent complaint of all-season tire users, as it can take seemingly forever for your tires to get up to temperature on a cold day. Not only does this increase cold-weather grip, but it also increases comfort in cold weather.
