Bighorn
Top Supercharger
You can still configure a P85D and get 19" snows. No reason not to as it's the better choice for most. Work great on my P85+.
The US site also allows the P85D to be optioned with a set of winter tires on either 21s or 19s.
Definitely just an add on. No way to get around the 21s.I'm going to go check this now, but I believe it allows you to ADD a set of 19 or 21 wheels with snow tires as an accessory package. It's not in lieu of the 21" summer wheels. It's certainly not priced that way.
So I added the 19" winter set to my order. Seems like this means my P85D will have a 295 mile range!
Not a joke. Going from 21" to 19" increase range to the same level as the 85D (295 miles).
The range increase comes from moving from a summer tire (sticker grip = more friction = lower range) to a harder all season tire with smaller contact width (less rolling resistance). Also the 19s are lighter which reduces rotational mass and also results in increased range.
Yeah, but not 20 miles worth of range.
If we're talking solely the difference between summer 21s vs lower rolling resistance all season 19s , then 20 miles extra range is definitely easily possible just by the tire/wheel switch alone.
The front motor in the P85D is the same motor as the one in the 85D, but tuned for more power. Just as going from 85 to P85 doesn't affect range, going from 85D to P85D shouldn't affect range either assuming the same 19" wheels. Hence the P85D with 19" wheels should have the same range as the 85D with 19" wheels (295 miles).
(a) I don't believe this is true, in reality. I might not have been on the forums as long as you, but I've never seen anyone claiming a 8%-10% increase in range due to wheel/tires switch alone. So you're claiming that this winter (next month), when I swap my 21" wheels for the 19" TSTs with 19" LRR tires (Hankook), that my range will suddently increase to 285 miles? I find that highly unlikely, but I'll let you know if it happens.
