Have you got your M3? Could you please confirm whether it has a heated steering wheel?Friday 26 March.
Delayed by a day. 16h local time I'll know it.Have you got your M3? Could you please confirm whether it has a heated steering wheel?
Good luck and I hope you will be the first one to report heated steering wheel in Europe ;-)Delayed by a day. 16h local time I'll know it.
Trying to talk my friend with early 20 MY and new 21 M3 w/heater to do a wheel swap and tell us the results.
The blue plug actually plugs in on the right side of the wheel (not sure why all the harness pictures have it flipped).
Daerik on YT do a live video every Sunday, and they confirmed that the new heated wheel would work by swapping the old wheel with a new one, but the SC wont enable it until "headquarters" says its ok to. WOMP. Search for their video from last night and skip about halfway through it and give a listen.Any update?
Note the "new" wheel design has stitching on it also. I was confused by this also. The difference actually is it's continuous all the way. The "old" design had seams in the 2 and 10 o clock positions, while new does not.Picked up my M3 today. Rang to confirm it would have heated wheel before purchase. It’s a MIC M3. from Vin and RN I was told that DID have heated wheel
Today at collection:
has external stitching
No setting to toggle on
rang Tesla. They advised it is a firmware issue, and will be sorted in April. Make of that what you will.
Command? "turn on heated wheel"?Picked up M3P with VIN 914xxx Yesterday and can confirm Heated Wheel and New Lights.
I've turned on the wheel heat using voice command... where do I find the screen for the seats/wheel?
Can't figure out if you're being sarcastic or not.. but "turn on wheel heat" works just fine.Command? "turn on heated wheel"?
Or "Alexa, turn on heat"? =)
Thanks, the screen I've seen is where you turn on your heated seats, there's a little heated wheel icon on the left, if I remember correctly.Can't figure out if you're being sarcastic or not.. but "turn on wheel heat" works just fine.
So... where's the screen for all these options? I can't seem to find it
My tan icon only brings up the image of the vents so I can adjust them....The fan icon in the center, then the lower tab on the left.
Ah that’s reassuring then. It does appear I have the new wheel. Certainly has the new scrolls.Note the "new" wheel design has stitching on it also. I was confused by this also. The difference actually is it's continuous all the way. The "old" design had seams in the 2 and 10 o clock positions, while new does not.
Thank you so muchThe fan icon in the center, then the lower tab on the left.
