Fitted 21” myp wheels on my m3p for anyone who is interested in doing similar size wheels just know it works. Ride is very compliant and not as harsh as I would expect it to be.
it does look evil, i give you that lol. hope its not a safety issue though given that you run on larger tires than normal (sidewall is same as 19" model 3 tires isnt it? so the whole wheel assemby has like 1" more diameter?)
Yes the overall diameter is the same, I think they complement the wheel well opening pretty well, but they are aggressive since it’s a 9.5 front and 10.5 rear. Cool thing about this is you can do a double stagger and run a 20” uberturbine in the front. I’ll get a few more angles.
15mm spacer would depend if you have a performance model or not, on the performance model the hat of the rotor is thinner therefor you might need an 18mm or a slip on to your 15mm if it’s bolted on. As far as camber goes my setup was on stock upper arm
