21" Arachnid Rims on Model X - Load Ratings
So I looked at my brand new Referral Rims and they now have a load rating stamp of 750kg per rim which equates to 1,653.47 lbs. Prior threads stated that Model X was too heavy for the Arachnid Rims, but looking at the new set of rims it can handle up to 6,613 lbs.
My Model X 90D 2017 GVWR per the door jam sticker is 6660lbs. So let's just say, I remove some weight and fix the offset to 35 can I put Arachnids on my Model X?
I also need clarification if the GVWR noted on the door includes the stock 20" Slipstream rims & tires which weigh in at 130.4lbs. The Arachnid rims weigh 105.7 lbs, 24.7 lbs, so if there is a reduction of rim weight the GVWR would be 6660lbs - 24.7 = 6635.3, so only need additional 22.3 lbs of weight reduction to make it work? Anyone know what I can remove to make it work?? lol
Here are the specs for the Arachnids:
  • Size: 21X8.5" front, 21X9.0" rear.
  • Offset: +40 front, +40 rear
  • PCD: 5X120
  • Center Bore: 64.1mm
Here are the specs of the 20" Slipstreams:
  • Size: 20X9.0"(front), 20x10.0"(rear) Note: Tesla later changed rear wheel to 20x9.5"+35
  • Offset: +35 (front & rear)
  • PCD: 5X120
  • Lug Nut Specs: 13/16, 14X1.50 Thread
Reactions: Cowby
No.
You need to look at the GAWR FRT and RR ratings. Rear Arachnids are rated at 750kg and front (smaller) at 638kg, and these happen to exactly match Model S rear and front axle ratings (divided by 2), respectively. But the GAWRs for Model X are significantly higher and the Arachnids would be grossly underspec if you put them on the X, which is why they are only approved for the S. (And this large deficit in weight rating holds even if you happened to use 4 of the larger size wheel).
No.
Wondering if GAWR is more important when you’re trying to tow. Numbers seem to be safe if you’re simply using it as a car.
i agree with this bit...the car weighs roughly 5531lbs for the P100D, 5421lbs. for the 100D, 5381lbs. for the P90D, 5257lbs for 90D & 5185lbs. for the 75D.
i drive 95% of the time by myself and periodically with 1 or 2 passengers and even with the occasional full load i'd barely be hitting 6600lbs. i can't tow as i don't have that package either.
i've been wanting to do this from the day a saw the gorgeous Black Arachnids.
GAWR, GVWR, GCWR are all ratings stating capacity, but that's just to cover a Manufacturer in case of misuse, neglect, etc...
let me know if you can get those Arachnids on the X! :D
Reactions: Cowby
Yeah. GAWR is significantly higher in the X for towing. If you use those numbers to see if the wheel will work, then the wheels will be under rated. But I don’t think it’s a good measure to see if a wheel would work for a certain car. Each front wheel is rated at 650kg and each rear is rated at 750kg totaling over 6100lbs. So the actual wheels can definitely handle the weight. Just wouldn’t be good for towing.
That looks sick. Just needs wheel spacers.
The main goal is to have something less boring then the 20” air streams but just as efficient as far as energy. Don’t like the idea of losing 10% or more in range!! Will monitor the energy usage with these wheels. If it doesn’t work, will wear the tires out and move on to something new.
Reactions: Cowby
Can you upload some better pics? Side view as well? Thanks’ considering the same thing but with powdercoated black arachnids.
Definitely looking into spacers.
Well done! :cool:
6f65a5e0-298a-40a4-b163-5fd8b5fc9ed0-jpeg.292450
