What’s the status of these?
Hey all, thanks for all of everyone’s hard work on all of this. I’ve tried reading through most of this thread and if I understand correctly, if I wanted to do set up this 2nd front camera, I would need to contact artsci for deposit for the pcb, apple guru for the can bus and since I just missed the cable sets, source some cablesmyself, and a Tesla camera? Is that the general process? Thanks!
Did I miss my chance at buying one off these
Are the switch, the cables,and the canbus all being held to distribute at the same time? I've paid [ into all 3 projects but haven't seen any request for final payments or progress on the switch and cables recently.
Question, how does one call up the front camera? Doesnitnswitch automatically?
Is there a manaual switch?
If I install, does this eliminate the HDMl addon or the 360 camera add ons I’ve seen posted in the forums.
I suspect you will hear from artsci soon and amplify these comments. I have one of the first front cam kits. Let me answer your questions.
1. How does one call up the front camera. From what I have done and read others do, the default we use is the front camera is on all the time. The main point of the front camera being on the display most of the time is to see when you are pulling forward into a parking lot so you can see curbs, parking blocks, lamp/sign posts and walls. In this case you don't have to call it up. The artsci switch defaults to front cam on the display all the time.
But before someone panics, let me belay their concerns. If you don't want the front cam up all the time, then simply plug the front cam video feed into the reverse cam port and the rear cam video feed into the front cam port on the switch. The cable going to the display remains the same from the switch. I've done it, works just fine.
2. Does it switch automatically? Yes. It switches automatically. With the front camera on the display, just put the car in reverse and after a "blink to black", the rear camera with guidelines comes up. Put the car back in Drive or Park and it returns to the front camera view.
3. Is there a manual switch. Yes. There is a manual switch. Actually, there are two methods of manually switching. With the switch artsci includes a bluetooth/Homelink feature, and remote control. the remote is about the size of a thumb - a little wider. I suspect artsci drafted it from available products. Its got four buttons, but we only use one - the one labeled "D". Push and release and it toggles rear to front, front to rear.
And you can also use the remote to program a Homelink choice on your display. Mine shows up when I press the Homelink icon. I named mine Camera Swap [I authorize other names if you wish]
4. This front camera kit has nothing to do with an HDMI port or 360 degree camera addon.
The bonus that appleguru brings to the table is the easy way to install the reverse connection. Artsci produced the first kits in 2014 with the help of friends. Some how in 2013/14 he identified a source to a single wire in the car's wiring harness (on the right hand side under the carpet from a massive group of connectors) that triggered the reverse signal and activated the switch to send the rear view going to the center display. It worked great, until 2015, when Tesla changed the harness colors and locations. From then on, we could not find the wire that we could connect to the switch to automatically switch from front to rear. We could still use the remote or Homelink choice, but it was not as graceful.
In March '17, I sold my '13 and bought a '17. For months I whined and wrestled with swapping the view. Then I had an idea. The key or trick to getting the switch to activate the swap from front to rear simply was momentarily sending 12v positive to the switch terminal. I could do with with a fused momentary switch connected to the same 12v source the power side of the switch was getting. But that still required manually doing -even though the switch could be convenient. Where can I get the same 12v signal at exactly the time I needed it? Ans: The backup lights in the liftgate. So, I tested first and then permanently wired a single 18/20 gauge wire from the liftgate's reverse lights through the liftgate, liftgate boot, to the body, and up from the rear to the driver side dash and attached it to the switch. BINGO. Back in business. But that was a lot of work. From what I have read on TMC, no one else was interested in repeating my effort on their car. Appleguru read about the effort and joined artsci's team by designing and producing a simple installation method. All you have to do is plug his package into the OBD II port under the dash the same place you connect the switch and video cables. Radically simpler than what I did. THANK YOU APPLEGURU. And THANK YOU ARTSCI for your switch.
Did I answer your questions? I enjoy bragging about this front cam kit, so I was pleased to help with the answers. This is absolutely on a scale of 1-10 a 15 in the mods that I have done to my Teslas. I use it every day, once or twice when I blew the fuse that powers the camera, I was handicapped parking. Now, that I know how to do it, I will not own/drive another Tesla without it. I am on the list for a second switch - a backup because I will not take the chance of something happening to my Tesla and winding up with one without the front cam kit.
