Hey, I very deliberately chose an amp that uses signal turn on vs remote turn on so that I wouldn't need to play with switched 12v in any form. Some people have played with this, but given the constant software updates, I didn't know if tomorrow they might change how something works and the behavior might change.RW,
I was trying to wire up the switched 12 and constant 12v today to a relay.
For the switched 12v, I am using a brown 12v wire that is coming out of the backseat air vents. For the constant 12v, I am splicing the cigarette lighter.
Strangely, the yellow switched 12v (+) wire turns into a black wire. I've never seen a black wire as (+). When testing with multimeter, black is (+). Picture attached for clarification.
Are you using another option for the the 12volts?
What are you using these 12v signals for?
