I have identified the cause of the "Cannot Maintain Vehicle Power" error when installing aftermarket amplifiers and drawing power from the CD-CD terminal under the rear seat. The cause is the DC-DC converter tripping when first powering on and trying to charge up the large input capacitors present inside the amplifiers. The large capacitance causes a high current spike on the converter, immediately tripping a current fault= and preventing it from powering on. Since the dc-dc converter turns on a few times over night to keep the 12v battery maintained, if it is unable to start up, the 12v battery discharges, giving the "Cannot Maintain Vehicle Power" error. I was able to trigger this error much more often by using an aftermarket 1 farad capacitor in parallel with my amplifier, vs without the capacitor, giving weight to the argument that the capacitance is the cause of the error. Using a cheap amplifier with a small input capacitor will probably avoid tripping the dc-dc converter, but any high-quality amplifiers, or stiffening capacitors will likely cause a lot of problems.
The solution to this is to use the attached simple circuit when drawing power from the DC-DC converter. The circuit works by limiting the inrush current to 12 amps when the DC-DC converter comes online by placing a 1 ohm resistor inline with the amplifier. However, this resistor would quickly overheat when the amplifier was in use, so a bypass relay is powered from the accessory 12V line coming from VC-Left. The car turns on the acc signal about 3 seconds after powering up the DC-DC converter, giving the amplifiers plenty of time to charge the input capacitors.
The only items needed are a 12v 30A automotive relay (amazon-link), and an approximately 1 ohm ignition resistor (amazon-link). If you are running a very high powered amplifier(s) , you may want to use 2 x 30A relays in parallel to avoid damaging a single relay.
I have am currently using this circuit in my Model 3, with a 800w Kenwood amplifier and a 1 farad stiffening capacitor. I have verified that it does allow the DC-DC converter to power-up without any error messages.
(Image-Link)
(Image-Link)
![relay-soft-start.png](https://i.ibb.co/pntDmt7/relay-soft-start.png)
