Air Lift for rear coils of Model 3?
Wow. I've never had handling issues, but would also like to avoid them. The bags I've used before have had valves that exit on the side, mid-spring. In many installations there's no place on the top or bottom for the valve.
I've only ever installed these on cars while using ramps. Things get much easier if you go up on ramps and THEN jack the car until just before the wheels leave the ground. This extends the springs as much as possible to allow for easier install. I agree that a lift would be even better!
Maybe you used a different brand? The air lift 1000 kit has the valve at one end
Well, if you come up with a way let me know. There is a channel on the bottom side of the control arm that the air line could run in after it exits from the hole at the bottom of the spring seat. Its protected by a plastic cover over the control arm. But from there I'm not sure, there would obviously have to be some slack then if running back together to a T under the rear to allow control arm movement, and where to secure it. When I get some more time I'll take a look under the rear aero shield
Just because I'm a wee bit sensitive about looking like either:
a. An idiot or
b. and old guy who's lost all of his faculties...
I'd like to present the Airlift 1000 side nipple! This is my 2002 Rav4EV installation, as well as the actual instructions from the site to prove that I didn't make it up.
I can tell you that I never did. My intent was to add a trailer hitch, but I didn't get to that yet either. So far I haven't missed having bags on the back. But if somebody confirms what ACTUALLY fits and works, that may just put me over the top and do it. I so liked having them on past cars.
Hey ok cool . I will see that airlift part number from the above post works . It will be here in the next couple hours . I have the Stealth Hitch on my car ! Will let you know how things go . Thanks
I installed the kit today . So far everything works and feels great . Just got done taking a test drive! Next test will be with my small trailer towing ! So airlift kit 60743 fits perfect
Reactions: TORQU3
