Turn Sentry mode off. It sucks battery. Also, cabin overheat protection. Both of those features suck battery. Overheat protection maybe leave on if it’s hot.So: I leave my 10 day old MY at the airport five days ago.
It had 55% charge , but has dropped markedly each day.
A few questions
(i) If my return from my trip is delayed, it could be flat ! Will Tesla roadside assistance come out?
(ii) Is my car faulty ?
(iii) What do you guys do if you take your family on a two week holiday ?
A few questions
Not a bad idea when you consider the cost and risk of parking around Newark! Of course, from East Brunswick, you could just walk. I would do the same - Uber from Sussex County.When I ultimately receive my Y and I'm flying out of EWR, I'll just leave it plugged in in my garage so it will have a full charge upon my return and take an Uber both ways to and from the airport.
I would never park in the airport. We always park at an off site lot 5 minutes away that is gated, manned 24/7, has both indoor and outdoor parking and a free car wash for stays a week or longer.Not a bad idea when you consider the cost and risk of parking around Newark! Of course, from East Brunswick, you could just walk. I would do the same - Uber from Sussex County.
I’d rather park at the airport and not come back to swirlmarks on my car, even if they’re free.I would never park in the airport. We always park at an off site lot 5 minutes away that is gated, manned 24/7, has both indoor and outdoor parking and a free car wash for stays a week or longer.
your car is normal. This is what they call vampire drain. A small amount of energy is being used to monitor things and maintain your battery. Your rate of drain is actually slower than most people who inquire about it. Less than 2% per day will last you quite a long time. And as someone else noted it gets more conservative as you drop to a lower state of charge. The only concern is will you have enough charge to get home or a supercharger?So: I leave my 10 day old MY at the airport five days ago.
A few questions
Turn Sentry Mode off.
Don't open the App.
Should be fine.
Vampire drain ?your car is normal. This is what they call vampire drain. A small amount of energy is being used to monitor things and maintain your battery. Your rate of drain is actually slower than most people who inquire about it. Less than 2% per day will last you quite a long time. And as someone else noted it gets more conservative as you drop to a lower state of charge. The only concern is will you have enough charge to get home or a supercharger?
Since when is 4 days a significant period of time?yes to all the above
I made a video because it just happened to a friend
“ I would never park at an airport”I would never park in the airport. We always park at an off site lot 5 minutes away that is gated, manned 24/7, has both indoor and outdoor parking and a free car wash for stays a week or longer.
Thanks roadmap … pretty much the only helpful reply ! (Well one of two !)I have just come back from a 10 trip to the US. I left my 3 at Gatwick short stay, I had 61% when I parked, I turned off sentry and made sure I parked in the multi story away from direct sunlight. After I walked away from the car I did not look at the app until I was in baggage claim upon my return ……. I was dreading it and already had a back up plan of the Crawley super chargers! I was amazed that it said 60% so I only dropped 1% in 10 days.
1. I believe they come out once for free in this instance (user caused battery depletion). They used to offer that, not sure if they still do, but yes they can come out and tow you to a supercharger if needed (but this is definitely user caused).
2. No, not in the slightest. Sentry mode will drain between 20-40 miles a day. You either turned sentry mode on, or have it set to be on automatically when you are not at home, so this is being caused because you turned sentry mode on during an extended parking situation.
3. Either ensure sentry mode and cabin overheat protection are off, or ensure that wherever you park for your trip has EV charging (many do, and many more are adding it). Also, ensuring that you park with enough SOC (state of charge) to lose 2-3 miles a day and get to a supercharger when you come back, if needed.
Drain will be no more than 3 miles a day when sentry is off and cabin overheat protection is off AND you do not open the tesla app to "check on the car" frequently. Drain will be around somewhere around 20-25 miles per day if you use sentry, and more if you also have cabin overheat protection or standby summon on.
TL ; DR a week trip with sentry mode ON while parked, will see the car use about 140 "miles" of range (7 days times 20 ish miles a day). A week trip with sentry, cabin overheat protection and standby summon off, and only "checking the car" 1-2 times a day at max, will see around 20 miles TOTAL lost during that 7 day period, and likely less than that if you can keep from checking on the car.
