gling
I have the Conti DWS+ in 255/35/20 on my 2021 M3P w/o any spacers in the front on stock suspension. No rubs or issues with clearance FYI.
Thank you for this information!I have the Conti DWS+ in 255/35/20 on my 2021 M3P w/o any spacers in the front on stock suspension. No rubs or issues with clearance FYI.
I think aftermarket 19” wheels with the right offsets would fit but the stock ones (sans spacers) are questionable(?). I’ve seen it being discussed on other threads but can’t remember the details.Do 19s fit on the 3P? A bit of extra sidewall helps in the winters.
And of course you’d rather have two sets of wheels & tires rather than mounting and dismounting tires on the same rims over and over again.
Many aftermarket 18" and 19" wheels fit. Especially any wheel made for direct M3P fitment with the stepped hub, will fit. (Would be silly to match the hub lib and then not have clearance!)Do 19s fit on the 3P? A bit of extra sidewall helps in the winters.
When I test drove the LR with 18" aeros, whatever stock tires those were (prolly the MXM4s or whatever), they were mushy in the transition to a spirited highway onramp. So, it's good to hear that other tires don't suffer that fate--it was *disconcerting*....
I was worried that I might find the taller 245/45 sidewalls too mushy, but not at all with summer performance tires. Most all-seasons will feel softer of course (especially if any snow capability), and for sure any real snow tire will, but the point is the taller sidewall performs completely fine, within the confines of your chosen tires.
I've never had good luck selling used tires. I usually end up selling all 4 for the price of 1 lol.I picked my M3P up last Tuesday and just dropped it off at a local tire shop to swap out the summer tires for the Continental Extreme Contact DWS06+ all-seasons. So, I will be looking to sell the set of 4 Pirelli P-Zero summer tires with only 100 miles on them soon. Anyone have a thought as to how much I should sell them for?
For what it’s worth, I sold my tires locally for $600 with <75 mi on them.I picked my M3P up last Tuesday and just dropped it off at a local tire shop to swap out the summer tires for the Continental Extreme Contact DWS06+ all-seasons. So, I will be looking to sell the set of 4 Pirelli P-Zero summer tires with only 100 miles on them soon. Anyone have a thought as to how much I should sell them for?
Which wheel do you have? Pictures? TIA!Many aftermarket 18" and 19" wheels fit. Especially any wheel made for direct M3P fitment with the stepped hub, will fit. (Would be silly to match the hub lib and then not have clearance!)
I have 18x8.5" ET35 wheels with 245/45R18 tires on my 2021 M3P right now. Summer tires for me at the moment, so not helpful in this thread, but the setup feels GREAT, better than stock in every way - grip, ride, nimbleness, steering feel, and of course I'm way less stressed about bad roads / potholes. I'm planning to use these wheels for winter tires once the current tires wear out.
Yup! It's mostly about the tires. MXM4 are a mushy mess if you care about performance and feel. When you downsize and switch to mushier all-seasons or especially winter tires at the same time, you take a triple whammy. (I'm writing this from experience. On past cars I've switched to winter tires in stock size on the stock wheels, and also switched to winters on separate, smaller diameter wheels.)When I test drove the LR with 18" aeros, whatever stock tires those were (prolly the MXM4s or whatever), they were mushy in the transition to a spirited highway onramp. So, it's good to hear that other tires don't suffer that fate--it was *disconcerting*.
Wheels are Titan7 T-S5 18x8.5" Satin Titanium.Which wheel do you have? Pictures? TIA!
Those look great! And really show the red calipers. Do you see any better efficiency compared to the big/heavy Ubers? did it help 0-60 time at all? I've heard mixed responses on both fronts.Wheels are Titan7 T-S5 18x8.5" Satin Titanium.
Tires are Bridgestone Potenza Sport 245/45R18 100Y XL. Summer performance tires, not what you're looking for in this thread, but I highly recommend them for summer use!
Stock lug nuts with $9 set of gray covers that match pretty close. If you hold the covers in your hand they feel and look as cheap as the price, but standing next to the car they're fine and blend in well. I think they're worthwhile just to avoid grime and stuff getting onto the lug threads with the open-ended nuts.
The Titan7 wheels are forged, about $2000 for the set of 4 in this size. Cheap as brand new forged wheels go, though still expensive compared to basic decent cast / flow formed wheels of course. They are machined to fit directly onto the M3P stepped lip hub, no spacers or anything needed. To me they look and feel great (in terms of fit, machining, finish), there is nothing I could nitpick especially for the price. I don't have much experience with aftermarket wheels but I've had OE forged BBS wheels (different car), which were great too, but honestly there's nothing about these that I can tell is any worse.
Now if money were no object I'd probably rock some forged BBS or HRE instead.(Well if they even offer direct M3P fitment.)
As mentioned my plan buying these was for them to become my winter wheels, once this first set of summer rubber is used up. I wasn't sure how I'd like the 245/45 width or sidewall for summer use, so I figured I'd try one set like that, and then decide exactly what diameter & width wheels I want for summer while switching these to winter duty. But with really good tires I'm liking this setup so much I might just stay with this size for summer too!
Edit: The advantage of forged - which may not be worth it in $ terms - is they will be stronger (less likely to crack), even while weighing less at the same time. You'll probably get 80-90% (total guess) of the subjective benefit though from decent flow formed cast wheels, which will still weigh much less in 18x8.5 than the OE Uberturbines.
I don't really know either answer, sorry. No straight line acceleration difference that my butt dyno can tell, though I haven't floored it from a dead stop. The extra grip from the tires does help traction coming out of turns!Those look great! And really show the red calipers. Do you see any better efficiency compared to the big/heavy Ubers? did it help 0-60 time at all? I've heard mixed responses on both fronts.
Thought I would share with you all what 245/35/20 all seasons look like on the uberturbines. (OEM is 235/35/20 btw).
I went with Continental DWS06 Plus tires, got them installed by Discount Tire after a little back and forth with them about a non-OEM tire size and they finally agreed to order & install. I kinda wish I had gone with 255/35/20 to get the sidewall more vertical (with this particular tire because I know they tend to run skinny). I can still fit my hand between the upper control arm and the tire easily so I'm farily sure they would fit, but it would prolly not help the economy of the car with more tread on the ground.
I've had DWS's before. They are fine. Not amazing in any weather condition, but now I can at least make it home if I get caught in unexpected weather.
View attachment 752400View attachment 752401
