connectjunkie
For what it’s worth, I have an A2 with an adaptive fuse installed. I also already have a 100A fuse. Mine connects to the house network via wifi.
I think the name “adaptive fuse” is a bit misleading as to what it actually does. Essentially they put an energy monitor on your main electricity feed that monitors the usage for the house so the A2 can ramp down the charge if you’re using a lot of electricity elsewhere in the house.
As I only have electricity and I have a sizeable ground source heat pump heating the house and doing hot water, my house does end up using a lot of electricity at once at peak times. Hence, I was happy to install the adaptive fuse.
One side effect - it means you get energy monitoring for the entire house (in aggregate) as well as for EV charging.
