Is there documentation of what is covered in the Annual Service?
From an old service record provided by the prior owner, the 2015 Annual was $600 and covered
The Service Advisor has been vague on what was done "covers a lot" "it's hefty" but says it doesn't cover AC, Brake Fluid & Coolant flushes which they wanted $250 for each. I've done brakes & coolant on prior cars so politely declined.
Also the test drive was 7 miles, which seemed a lot . . . is that typical?
- Checked torque of all suspension components
- Replaced AC System desiccant
- Flushed Brake Fluid
- Flushed Coolant
- Lubrication of all latches
- Removed PEM and cleaned
- Replaced wiper inserts
- Replaced key batteries
- Performed final test drive. Vehicle operation normal
