That's depressing.
Feel free to click without giving JP a penny, not his article: http://seekingalpha.com/instablog/1...ve-trains-for-class-8-trucks#comment-16062691As a special sneak preview; did you know that the cradle-to-gate energy to make a 1 kWh lithium-ion battery totals 472 kWh equivalents of fossil fuels, or that more energy goes into making an 85 kWh battery pack for a Tesla Model S than the car will consume in 150,000 miles?
It was so poorly done and filled with obvious misinformation that even casual observers should be able to dismiss as anti Tesla propaganda.
Preemptive warning, I feel a Petersen FUD fest brewing:...
Looking at this study http://www.transportation.anl.gov/pdfs/B/644.PDF which was coauthored by the same person who did the other study I linked I see where Petersen gets his numbers. Page 30 Figure 4 shows lithium at 1.7MJ used for each Wh of capacity, or 472 Wh per Wh, 472kWh per kWh. I don't know why there is such a huge discrepancy between the two studies, though I do see that they use 75 Wh/kg of energy density which is at least half of the pack level energy density that Tesla actually has. Using 150 Wh/kg then it would be 236kWh per kWh, 20,060 kWh energy used for the whole 85 kWh pack.
When your argument has no merit - complicate, confuse and obfuscate.
The 85kWh pack takes 20,050 kWh of energy to create.
Maybe. (That's using all energy inputs from mining to finished pack, if the study figures are correct, and using my revised density of 150 Wh/kg for the pack instead of the 75 Wh/kg used in the study.) As a reference using 320 Wh/mi the S would consume 48,000 kWh in 150,000 miles. Now the full honest comparison of EV vs ICE would subtract the energy used to create the ICE and it's accessories, including multispeed transmission, which should be more than the much lighter electric motor single speed gear reduction. I think the fuel creation energy I previously calculated for petroleum goes more towards a comparison of operational efficiency as opposed to construction efficiency. Even adding the energy used to build the pack to the operational energy for 150K miles equals 454 Wh/mi, compared to a 20 mpg ice which is 1,650 Wh/mi. from the tank to wheels alone.
Don't know if this counts as 10 words or less :redface:
And heeeeerrrrrsss Johnny! http://seekingalpha.com/article/126...-on-solar-power-integration-and-electric-carsPreemptive warning, I feel a Petersen FUD fest brewing:
