Any way to upgrade the dome lights
PNWLeccy
861
685
Seattle
@chojn1 Could you provide some more detail how to use the connectors in your links to run more than one led from the connectors in the right console 12v source?
I'd like to run LEDs under the screen like your example as well as 2 others under each front seat but not sure how to tap power without damaging original wiring
SemoTech
34
61
Hackensack, NJ
@PNWLeccy The kit that @chojn1 is selling for about $20 has the connectors on it. The wire is great to replace the existing LED light in the front cubby, but it's even better if you just use a splitter to keep the OEM light and also add the one for under the display. Click the MODS link in my signature below for a step-by-step with pictures and links to do this mod.
XLR82XS
D M C
Jul 26, 2019
3,091
1,719
SWFL | Vegas
I bought this console light and I plan on splitting the power when I install it.
PNWLeccy
861
685
Seattle
@SemoTech I went to go buy the console light from @chojn1 but it seems to be sold out. I can purchase a led with 12v wiring here but i cant figure out how to attach the proper connector.
I know @chojn1 has linked the mouser parts but I cannot figure out how these work/attach to the 12v wiring. Any ideas?
PNWLeccy
861
685
Seattle
I had a few requests for instructions on installing the LED so rather than answering each one individually, I made a video.
Hope that helps:
Instruction on making your own is here:
https://www.mymod3.com/led-light
CJ
Thanks for the install video @chojn1 !
I've read your DiY guide and i understand how the install should work but since your center console LED light is sold out, I was looking into making my own.
I know you included the plug parts in your DiY guide but I can't figure out how they should fit to the end of the 22 guage stranded wire. The part here https://www.mouser.com/ProductDetail/TE-Connectivity/1-1534155-1?qs=wJnlJUhwIAnXqTlfD8bSUQ%3d%3d&gclid=CjwKCAjw4PHZBRA-EiwAAas4ZvfwvuovstOnhbTBwB8fCYFN6OkIeYnOy5lTw6HyaQv1XixEytUJFBoCbhMQAvD_BwE looks like all the other led plugs ive seen. However, I cannot figure out what the function of the other 2 parts are that you've included (https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/1534027-1?qs=%2fha2pyFadugsl8QPPxJnwzxntaX1vMTXT54QC%2fUVDj1XxUHC7rkjdg%3d%3d and https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/1-928918-1-Cut-Strip?qs=%2fha2pyFaduhhx9kzLQmIy%252b8Wd93yK%252bbd5J9OK%252bDrBuMCRnoXv95n20QRK4Rpm0hD)
chojn1
393
1,062
Sugar Land
Hi @PNWLeccy,
The pins crimp on to the end of the bare wires coming from the LED. You do need a crimping tool for this.
The cover plate slide on to the plug once the pins are in place to secure the wires from coming loose.
CJ
PNWLeccy
861
685
Seattle
Hi @PNWLeccy,
CJ
Ah I think I now understand. Unfortunately, one of the cover plate parts has a minimum order quantity of 100 so I don't think I'll be going that route. I would prefer to buy your pre-wired led but I see it's currently out of stock.
If i was to buy this wired led https://www.amazon.com/gp/product/B01ENC1S3I/ref=ox_sc_act_title_4?smid=A6XWG1D8Q4A4V&psc=1 and connect it to this connector https://www.amazon.com/gp/product/B07R77FQ3R/ref=ox_sc_act_title_5?smid=A1THAZDOWP300U&psc=1 with this solderless clip https://www.amazon.com/gp/product/B07F3HVQ2Y/ref=ox_sc_act_title_2?smid=AKJJC2TC2V4Y0&psc=1 do you think that would work?
Really appreciate your help!
Mr X
Future Martian
Jan 18, 2013
2,106
1,533
Simi Valley, CA
Don't know why the dome lights are slightly yellow and not bright white. I have them turned off for now
Ordered blue transparent wrap and will cut out and put over the lights so my interior will be illuminated blue
St☰v☰
787
529
SoCal/Texas
So what I want to do, is add a rectangle light, similar to those in our trunk to the area just in front of the OH light/switch that will illuminate the dash and seats. So Is it possible to pull the current housing down and attach to the wires of the little round light on the driver's side?
It's kinda like the OE lights in the trunk and puddles, all of them were way too dim, so I've upgraded those, but I really want more light in the front cabin area.
PNWLeccy
861
685
Seattle
@PNWLeccy,
You can approach it that way.
But I would use this connector instead to avoid cutting any existing wire:
https://www.amazon.com/Wire-Connect...d_r=62d276f4-ee44-4894-82c0-3d8c208111fa&th=1
Let me know if you are still stuck, I may have a few parts left in the shop I can send you.
CJ
@chojn1 I finally took apart the center console and the 2 pin jst connector I had attached to my LED didnt fit into the connector in the console. Is the center console connector a 3 pin? I know you included the mouser parts but I have to buy the whole connector
chojn1
393
1,062
Sugar Land
@St☰v☰
There is really no room at that spot.
robinsr
New Member
Apr 8, 2021
florida
Sorry about that. Was not sure if anyone was interested.
Open the right side of the center console.
There is a two wire (brown and white) plug which connects the LED from inside the middle center console to 12v.
Unplug this, and plug in your own 12v LED. The plug/connector is the same one used in all the interior LED's.
Attach that LED to the underside of the display mount.
The lid open/close sensor is not wired in line with this power line, so you're good to go.
This is the LED strip and connector I used for the trunk. You only need a strip of 3 LED for this purpose.
Where do you get the connectors for these lights?? I want to wire in a small led in a model 3 for the back seat area.
